using diferents components
kalmar79
Been thanked: 4 times
Post by kalmar79 »
Hi, I want to make a boat toy, using a dc motor and a servomotor. I want to turn on and turn off the dc motor with a same push button and change the servomotor with a mini joystick(like play station controller). I am using the 16F628A and 4Mhz XT.
I have more or less the push button program, but I don't understand how join the servomotor program in my program with push button on off. The two devices working separately with the same PIC.
I see the mini joystick has two potenciometers, I only need to use one.
What I want is to start a DC motor and control the boat with a servomotor. Then I will use a 433Mhz RF transmitter.
boton on-off.fcfx
(6.19 KiB) Downloaded 253 times
Re: using diferents components
Sounds like a good project, I've replied to your post here.
http://www.matrixtsl.com/mmforums/viewt ... 54&t=19967
Let us know how you're getting on.
