Compile Error USB Slave Component
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Post by QMESAR »
Hello Team.
I am having a syntax error report when I compile this simple example Flowchart with a PIC18F4550 Selected as device.
The flow chart contains only a main and the slave service makro attached my flowchart
Please help me out :D
I am still having problems to install the driver on WIN10 however it worked in WIN7 (I am using WIN7 machine at the moment)
USB_Slave.rar
(77.39 KiB) Downloaded 241 times
Re: Compile Error USB Slave Component
Hi Peter,
This should work correctly now. The Slave Macro property was empty, I've now populated this with the slave_service name of your service macro.
Test_USB_Slave.fcfx
(9.08 KiB) Downloaded 247 times
QMESAR
Post by QMESAR »
Hi Ben.
I am sorry I am trying to find my way through this :D
Thank for the updated Flowchart however it now complains that the RunsSlaveservice ()has to few parameters :oops:
I hope soon I will be off your neck with this !
(21.98 KiB) Downloaded 2136 times
Hi Peter,
Aha yes sorry your slave service macro has a byte parameter so this also has to be specified in the component properties.
QMESAR
Post by QMESAR »
Hi Ben,
Thank you so much, :D
The issue is solved and I have understood the problem :D
