12F1840 UART interrupt ?
seokgi
Has thanked: 18 times
Been thanked: 16 times
Post by seokgi »
Hi. Everyone.
I worked 12F1840 with ds1307. I wanna clock to UART. But UART INT is not work. I don't solve.
Please Help me.
Thank you
test].fcfx
(10.03 KiB) Downloaded 214 times
Re: 12F1840 UART interrupt ?
Within your interrupt macro, you have got a SendString rather than ReceiveString.
So nothing will be assigned to UART_Recive1 as your're not using that value anyway.
seokgi
Post by seokgi »
Thanks your answer.
I did a program to resend the data I received to confirm that the data sent from the pc to the pic was cleaned,
but the data would not come back. I do not know what I did wrong. I suspect that the interrupt is not working properly.
test1.fcfx
(10.38 KiB) Downloaded 207 times
Hi seokgi,
I have noticed you have RS232 in software mode.
The RX interrupt with only work in hardware mode, so you will need to select
Channel 1
Also I would not recommend delays within interrupt.
Another thing wrong was Enable interrupt component was within your main loop.
Interrupt enable should only be accessed once.
Can you try the attached flowchart.
test2.fcfx
(10.84 KiB) Downloaded 228 times
seokgi
Post by seokgi »
Thank you.
I fully understood your advice.
However, APFCON error occurs when I execute it.
Target folder: D:\Work\Study\Flowcode\DS1307
Source name: D:\Work\Study\Flowcode\DS1307\test2.fcfx
Title:
Description:
Device: PIC.12F.12F1840
Generated by: Flowcode v7.3.0.7
Date: Friday, May 11, 2018 00:21:25
Users: 1
Registered to: seokgi
Licence key: HNMEMM
http://www.flowcode.co.uk
Launching the compiler...
C:\Program Files (x86)\Microchip\xc8\v1.45\bin\xc8.exe --chip=12F1840 "test2.c" --MSGDISABLE=359,1273,1388
Microchip MPLAB XC8 C Compiler (Free Mode) V1.45
Build date: Nov 15 2017
Part Support Version: 1.45
Copyright (C) 2017 Microchip Technology Inc.
C:\Program Files (x86)\Flowcode 7\CAL\PIC\PIC_CAL_UART.c: FC_CAL_UART_Init_1()
370: APFCON = APFCON | ();
^ (195) expression syntax
373: APFCON = APFCON | ();
(908) exit status = 1
C:\Program Files (x86)\Microchip\xc8\v1.45\bin\xc8.exe reported error code 1
FINISHED
There is a fix for that.
Just make a copy of 12F1840.fcdx within Flowcode 7\FCD\PIC\ directory, then replace it with fix LeighM posted here
You must click on Reload (or exit and restart Flowchart) for changes to take effect.
I have tested the flowchart I posted with hardware and I can confirm all working for me.
