Pickit3 programming problem in Flowcode V7
Ocaltekaustralia
Post by Ocaltekaustralia »
using 30 Day trial of Flowcode V7. loaded pickit3 programmer , cant get it to accept chip name . what am I doing wrong?
C:\Program Files (x86)\Flowcode 7\compilers\pic\bin\xc8.exe -P12F1840 -FLEDblink.hex -E -M -Y
: : (902) no chip name specified; use "PICC --CHIPINFO" to see available chip names (error)
Ocaltekaustralia
Re: Pickit3 programming problem in Flowcode V7
The compiler parameters are correct and the window has all the details , it just isn't picking it up
It looks like you may have put the programmer parameters into the compiler settings.
There are three option tabs in the compiler options window, compile, link, program. It's the program tab that you need to override for the PICkit to function.
This should look like this.
C:\Program Files (x86)\Flowcode 7\compilers\pic\bin\xc8.exe --chip=12F1840 "LEDblink.c" --MSGDISABLE=359,1273,1388
