STM32F051 Disco programming error
STibor
Has thanked: 116 times
Been thanked: 113 times
Post by STibor »
Hello!
STM32F051 discovery program upload does not work.
Error message:
C: \ Program Files (x86) \ Flowcode 7 \ compilers \ STARM \ batch \ stm32prog.bat reported error code 1
STM32F303nucleo, STM32F746nucleo works fine.
log.txt
(6.92 KiB) Downloaded 285 times
Re: STM32F051 Disco programming error
Thanks for letting us know. Please can you try this updated definition file. Simply copy to your "Flowcode 7/FCD/ARM" folder and restart Flowcode.
32F051Discovery.fcdx
(30.61 KiB) Downloaded 301 times
If this doesn't work then please can you tell us what name the board appears in the root "My Computer" / "This PC" folder. We are currently guessing it's like the others and called "DIS_F".
STibor
Post by STibor »
Benj wrote: If this doesn't work then please can you tell us what name the board appears in the root "My Computer" / "This PC" folder. We are currently guessing it's like the others and called "DIS_F".
No names found, no disk drive.
I've updated the driver, no effect.
I think he used to work well in win7. Under Windows10, no disk drive is created. Device Manager only installs a USB drive.
The board is good because it works well with Atollic.
Has thanked: 481 times
Been thanked: 699 times
It looks like the original FCD file for this board might be correct, as the STM32F051 Discovery board has onboard ST-LINK.
When you plug the board into the PC USB does "STM32 STLink" appear in the devices list?
STibor
Post by STibor »
LeighM wrote:It looks like the original FCD file for this board might be correct, as the STM32F051 Discovery board has onboard ST-LINK.
Hy,
Yes, it is installed.
I made a little video.
Driver / Atollic Truestudio / Flowcode
https://www.youtube.com/watch?v=UQjECBi ... e=youtu.be
In your Flowcode installation directory \compilers\STARM\batch
there is a batch file stm32prog.bat
could you replace it with the one attached, then try again and post the .msg.txt file
Also could try closing Atollic.
stm32prog.zip
(404 Bytes) Downloaded 313 times
STibor
Post by STibor »
I changed the files, not good.
stm32f051disc.msg.txt
(7.01 KiB) Downloaded 305 times
STibor
Post by STibor »
I attach the Benj FCDX file log.
stm32f051disc_BenFCDX.msg.txt
(7.07 KiB) Downloaded 311 times
That is strange,
in the first log there is neither a message from Windows saying it cannot find ST-LINK_CLI.exe
or any messages from ST-LINK_CLI.exe.
Do you have in your Flowcode installation a directory \tools\ST-LINK Utility with ST-LINK_CLI.exe?
If so, can you run it and see if it outputs anything.
One workaround would be to program the device, with the hex file produced by Flowcode, using the ST GUI ST-LINK Utility
It can be found here, scroll to the "Get Software" button at the end of the page.
http://www.st.com/en/development-tools/ ... nk004.html
Thanks,
Leigh
edit:
You also mentioned Windows 10
I wonder if it is an issue with Windows Defender antivirus?
STibor
Post by STibor »
Thank you it works!
Installing STM32 ST-LINK Utility (STSW-LINK004) solved the problem.
(103.03 KiB) Downloaded 2913 times
