help with dac 8552
RLOPES780
Been thanked: 3 times
help with dac 8552
Post by RLOPES780 »
I want to use the 16 bit dac8552.
Its serial input is 24 bits 8 commands + 16 data.
I would like a sample writing code by sending these 24 bits.
Because the first byte is command and the other 16 are data.
So the data range from 0 to 65535. My question is also how do I turn this into 2 bytes. Second byte data set and third byte data set?
Thankful;
Ricardo.
dac8552.pdf
(1.03 MiB) Downloaded 277 times
RLOPES780
Re: help with dac 8552
Post by RLOPES780 »
I would just like an example code to do this
Thankful;
Ricardo.
Hi Ricardo,
Here is a very basic example.
DAC_Example.fcfx
(7.72 KiB) Downloaded 284 times
I've created a macro called Send Command with two parameters, an 8-bit command and a 16-bit data value.
This is then split up into three bytes and sent to the SendByte macro. This could be replaced with a SPI macro call or a bit banged routine to output the data a bit at a time.
