Converter is not working
Osta
Been thanked: 13 times
Post by Osta »
After I prescribed Compare$()
Stopped working ToString$()
Remained workers only the text !
This is after update!!!
And all I had from this project to remove all the macros and put them zanovo
Because after the update the compiler simply did not see them!!!!
In General horror!!!
Osta
Re: Converter is not working
Post by Osta »
MD.fcfx
Proj
(14.33 KiB) Downloaded 250 times
Osta
Post by Osta »
The compiler stopped working at all !!!
Has thanked: 481 times
Been thanked: 699 times
I am not sure exactly what problem you are reporting.
But I did notice a couple of issues:
Text normally needs the background drawing too, so you need transparency turned off...
C code does not simulate, so the variable will not increment in the simulator unless you use a calculation icon...
Hope that resolves your problem, if not please could you give more details.
Leigh
Osta
Post by Osta »
I'm not using the simulator!
Can I use my code ?
I have an electronic Board with a processor.
Now nothing works !!!
SPI - not working !
display not working!
The display is not initialized
and no cleaning !
Previously cleaned!
Could you make the above changes, then "Compile to chip" and post your MD.msg.txt file?
Osta
Post by Osta »
It's my fault.....
I made a delay at the beginning of the code and everything began to work!!!
Probably a programming problem...
My apologies!!!!
I'm confused with the Compare$ function
With respect Osta :)
MMD.fcfx
New
(10.37 KiB) Downloaded 259 times
OK, glad it's now working.
The Compare$ function returns 0 if the strings are the same.
