Problem with mloader
waligator
Has thanked: 5 times
Been thanked: 7 times
Post by waligator »
Hi everyone,
I just received a new programming deck (EB-006-00-09).
I installed mlaoder and made the change in the compiation options.
Unfortunately, when I want to configure the chip, I have a mloader error message.
Are the settings I entered correct?
Another question, can I do real-time debugging with Flowcode V5?
thank you in advance for your help
Re: Problem with mloader
Hi Steve,
mLoader should be used as the programmer, so the first two text fields are correct.
However PPP is still required in v5 to do the chip configuration settings so the last two text fields need to be reverted back to how they were.
waligator
Post by waligator »
thank you so much, everything is ok
