Unable to resize window
stevebeale
Has thanked: 3 times
Been thanked: 2 times
Post by stevebeale »
hi
i am unable to resize > Project Options/ configure the Name Size and value the drag option to open up a section is not working for me
so i cant read names.
also if using the Micrchip demo 44 pin the chip displays wrong chip. as it should be a 44 pin not a 40 pin as shows.
i have lots of problem 6 pages ill post some else as im not certain what the problem is
Ben probable leave you a zip file it be easier
steve
Steve Beale
Has thanked: 481 times
Been thanked: 699 times
Re: Unable to resize window
Do you mean the column positions?
If so, you can widen these, but you need to grab the vertical line in the data section, not the title header...
