counter
siliconchip
Has thanked: 101 times
Been thanked: 25 times
counter
Post by siliconchip »
hi ive made myself a simple flowchart which will become part of a bigger project but this is increments a count to 12 by each button press then when reaching 12 it decrements to 0 however when counting down past 10 i cant lose the 0, im sure there is a simple solution but ive yet to find it, can someone show me the errors of my ways please :oops:
cheers bob
counter.fcfx
(12.17 KiB) Downloaded 301 times
Re: counter
Hi Bob,
You could either clear the LCD when you drop out of the first "until scan = 12" loop.
Or you could format the number so the value on the display is always 2 characters.
(10.37 KiB) Downloaded 2082 times
siliconchip
Re: counter
hi benj
as always thanks for the reply, ive tried both of your suggestions and found using the decision box in the second routine works fine, it seems such a simple solution but i couldnt find it :oops: thanks for the tip
cheers bob
counter.fcfx
(12.75 KiB) Downloaded 319 times
