ENC28J60
Roy Johnston
Flowcode V4 User
Has thanked: 2 times
Been thanked: 34 times
ENC28J60
Post by Roy Johnston »
Is there a component whereby I can pass a variable to this chip for the IP and Mac.
I would like to read values from eeprom to this chip.
thank you in advance
Re: ENC28J60
Hello Roy,
It should be something we can add to the component fairly easily.
Let me have a quick look for you.
Re: ENC28J60
Hi Roy,
I've added the modification for you via two new macros in the component. Simply run the Help -> Check for updates and this should allow you to download the latest ENC28J60 component file.
Roy Johnston
Flowcode V4 User
Re: ENC28J60
Thank you,
I will check a revert back.
Roy Johnston
Flowcode V4 User
Re: ENC28J60
Thank you very much.
it working.
