BL0136 - Component issue
petesmart
Has thanked: 187 times
Been thanked: 140 times
Post by petesmart »
Hi Ben,
I have been doing some more testing on the BL0136 component...
In addition to the simulation issue that I described in a previous post viewtopic.php?f=78&t=20260, I found another odd problem.
When requesting the IP address using the CheckTCPServerIP macro on the hardware it returns the MAC address rather than the expected IP address. The odd thing I observed is that when simulating in ICD mode both the hardware and the simulation shows the correct IP addres :?: s - this is on the LCD display and simulation debugger panel.
Test program attached
bl0136 test.fcfx
(20.84 KiB) Downloaded 274 times
Best
Pete
sorry about that Chief!
Re: BL0136 - Component issue
Hi Pete,
Hmm same for me, I'll look into this for you.
Edit .. Should be fixed now. :D
petesmart
Post by petesmart »
Hi Ben,
Component now doing as it should... thanks.
Please see previous topic - simulation is still broken...
Best
Pete
petesmart
Post by petesmart »
We are getting closer Ben,
I have sent you a PM wit the details
best
Pete
