IMPORTING a file from Flowcode v7 to Flowcode v8
Monie Jacobsen
Has thanked: 17 times
Been thanked: 46 times
Post by Monie Jacobsen »
By IMPORTING a file from Flowcode v7 to Flowcode v8, you receive the following message!
Then shut down Flowcode v8 and again start Flowcode v8 and now I can work with the codecs first.
Do you have a suggestion to resolve the Import of Code from an earlier version.
See the picture below:
Best Regard
Monie
Has thanked: 481 times
Been thanked: 699 times
Re: IMPORTING a file from Flowcode v7 to Flowcode v8
Hi Monie,
Could you post the V7 project that causes this?
Or send it to me via PM?
Leigh
Monie Jacobsen
Hi LeighM
Can you use this version from Flowcode v7 ECIO40P:
File from flowcode v7:
SolarTrackerECIO40P-Update.fcfx
(274.95 KiB) Downloaded 256 times
Best Regard
Monie
Hi Monie,
You don't need to use "Import", that is for much older projects.
Please just "Open", or drag and drop, the V7 project, into Flowcode 8
Leigh
Monie Jacobsen
Hi LeighM
Ok, I was just sure it was Import that would be used here.
Do as you describe ;-)
Thank you very much.
Hope you can manage the summer heat :D
Best Regard
Monie
