PIC8F47J53 I2C Channel 1 incorrect ports/pins
streammaster
Has thanked: 7 times
Been thanked: 13 times
Post by streammaster »
Hi Ben,
I just spotted that the definition file appears to be incorrect for PIC8F47J53:
I noticed that the I2C port Channel 1 have incorrect association of the SCL and SDA pins.
Channel 1:
SCL currently $PORTC.3 should be $PORTB.4
SDA currently $PORTC.4 should be $PORTB.5
How this can be corrected.
I'm not sure if I use this config on new project would create a problem?
One thing: it appears that this setting has no issue with compiler, on the project which i originally have done in FV V7 and didnt touch the configuration but opened it in FC8. It compiles correctly for the physical hardware.
I do not understand the concept in your DCFX files so i need your help to configure it correctly.
Thanks,
Igor
Re: PIC8F47J53 I2C Channel 1 incorrect ports/pins
Hello Igor,
Many thanks for letting us know. I have now fixed the problem and added the fix to the v8 updates system.
See here for details on using the system.
https://www.flowcode.co.uk/wiki/index.ph ... ic_Updates
streammaster
Thanks for doing this!
Any chance to disclose what have you changed?
This was the change in the definition FCDX XML.
