Pic32mx230 slow spi clock
Alkaline
Has thanked: 42 times
Been thanked: 41 times
Post by Alkaline »
We are trying to use a ili9341 on pic32mx230f256B
We are successfully implement the macro glcd_ili9341. The display turn on and images appear on the screen.
We have only problem, the speed. Running at a very low speed
by measuring the clock on the sck pin we get 1.1-1.2Mhz.
Did any of you find the same difficulties with spi?
In attachment the clock configuration of pic32
The system clock running at 40Mhz (checked)
Best regards
MX230F256B_config.pdf
(233.65 KiB) Downloaded 313 times
Has thanked: 182 times
Been thanked: 179 times
Re: Pic32mx230 slow spi clock
Are you using a software SPI or hardware? Maybe you can post a printscreen from the SPI config.
Alkaline
Post by Alkaline »
Hi Stefan
Thanks for reply.
We don't call directly spi interface, we use the pin configuration in glcd_ili9341 .
In attachment the program
Best Regards
Flowcode8_display_ILI9341.pdf
(264.51 KiB) Downloaded 376 times
I've created a new ILI9341 SPI component for you which has the SPI CAL built in rather then simply bit banging out the data to the display.
Hopefully it should run significantly faster but has the downside now of having limited fixed hardware SPI pins and also the MISO pin connection. Note this isn't actually used and so doesn't need to connect to anything on the display. It's only listed as a heads up that you won't be able to use the pin for anything else.
Use the updates system to download the new component.
Let us know how you get on.
Alkaline
Post by Alkaline »
Hi benj
Thanks for reply.
We tried to insert the new cal but when we compile it returns this error
Unknown or missing port variable: $PORTC.2
best regards
MX230F256B_SPI_HW_new.pdf
(226.69 KiB) Downloaded 366 times
Alkaline
Post by Alkaline »
Hi Benj
thanks for reply
We have downloaded the new cal, but when we try to compile it returns the following error
display_test_9341_SPI_new_image_01_macro_test.c : 3788:error : Unknown or missing port variable: $PORTC.2
display_test_9341_SPI_new_image_01_macro_test.c : 3957:error : Unknown or missing port variable: $PORTC.2
best regards
MX230F256B_SPI_error_compilation.pdf
(226.39 KiB) Downloaded 330 times
(226.69 KiB) Downloaded 325 times
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Post by QMESAR »
Please stop to post pdf images !
No body can debug pdf's please post your flowchart !
It's compiling ok here for me on a PIC32MX device. Please can you check the component properties that all the pins and remap pins have correctly been allocated.
As stated by Qmesar we can't do much to debug your pdf documents, just attach the fcfx flowcode project and that should save you some time and allow us to investigate.
Alkaline
Post by Alkaline »
Hi benj
the version of pic we are using does not have the c port ( PIC32MX230F256H)
If you try to compile it, it will return the error
In attachment the flowchart.
Best regards
Display_test_9341_SPI_new_image_01.fcfx
(15.37 KiB) Downloaded 359 times
Many thanks I've found the cause of the problem now. The auto CS was left enabled in the SPI CAL component. I've now disabled this and pushed to the update system again. Fingers crossed if you update the component then it should now be fixed and compile correctly.
Alkaline
Post by Alkaline »
Hi benj
we downloaded the new release and ...... it works! :D :D :D
now we are pushing the bus to the limit 8)
Many thanks
Has thanked: 1135 times
Been thanked: 299 times
Post by jgu1 »
Hi Ben!
I can see that it is for Pic32 But has it any affect on Arduino? If not, is it possible to speed the SPI up for ili9341 on Arduino also?
Br Jorgen
Alkaline
Post by Alkaline »
When program call gLCD_ili9341_spi how there set this registers?
REGISTER SPI1CON
REGISTER SP1BRG
REGISTER SPI1CON2
Is it possible read the value of this register in flowcode .C output?
Now spi is running at 24 Mhz, in according to our pic datasheet is the maximum value.
Data Spi is 8bit framed. Is it possible increase to 32bit framed?
Best regards
The old ILI9341 component uses bit banged SPI using standard I/O.
The new ILI9341_SPI component uses the SPI CAL and so can use Hardware SPI on any target, including Arduino. Should run faster but downside is you loose the pin assigned to the SPI MISO.
The SPI properties can be set via the component properties. To see the code that accesses the SPI registers you would have to look in the CAL/FAMILY/CAL_FAMILY_SPI.c file.
You can read registers by using a C icon in your Flowcode project. first create a Flowcode variable called reg. Then add the following code into a C code icon and it will load the reg variable with the value from the register.
FCV_REG = SPI1CON;
We don't currently support this though I'll add it to the list for future investigation.
Alkaline
Post by Alkaline »
Hi benj
thanks for reply
we try to compile the program using the display with ILI9341 in HW SPI on a faster PIC32MX440F256H.
The compiler shows an error. It is possible to solve?
is it possible to improve the speed of the Bitmap Drawer component?
Best Regards
Display_ILI9341_MX440_new.msg.txt
(2.45 KiB) Downloaded 241 times
Display_ILI9341_MX440_new.fcfx
(20.29 KiB) Downloaded 226 times
It seems this device doesn't have a channel 1 but does have a channel 2, please can you check the component properties have been set correctly.
It should already be fairly efficient, though I can certainly have a look.
Alkaline
Post by Alkaline »
Hi benj
Thanks for you reply, now we are running on pic32mx440f256h at 40Mhz on spi.
You can see the screenshot of the oscilloscope.
In the second image, it is possible to note the time interval between a data packet and another. 1.780uS.
Is it possible reduce the time interval between data packet?
we have to load several bitmap as fast as possible
Best regards
Lagoda
Has thanked: 69 times
Been thanked: 61 times
Post by Lagoda »
Hi Ben,
I also experienced this phenomenon.
I am using PIC32MX370F512H MCU.
Would it be possible to shorten the time between sent bytes of the SPI bus ?
Best Regards,
Lagoda
