Flowcode 6 & PicKit 2 [SOLVED]
JLeith
Has thanked: 146 times
Been thanked: 26 times
Post by JLeith »
Hello all
I finally got my program back running after my old laptop crashed.
Now I found my old program on the forum.
but now I have a issue with the Flowcode 6 program working with PicKit 2.
I understand that my Flowcode 6 and PicKit 2 are old but still do the trick with my loading of Pic16 chips.
I have the CD version of PicKit 2 maybe I need a upgrade to PicKit 2 Version 2.50
I believe I have the wrong settings for the Compiler.
Getting a error message
C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\boostlink_picmicro.exe reported error code -2
I can't even save the Hex flies.
John
Re: Flowcode 6 & PicKit 2
Hi John,
If I remember correctly, with PICkit2 you can't have any spaces within your project name.
Try replacing spaces with underscores.
Also, can you post the programmer settings as well?
Can you actually see the hex file within the project folder?
JLeith
Post by JLeith »
Hello Martin
I'm in a total mess
I have googled for 6 hrs and still not getting Flowcode 6 to generate a Hex file never mind using the Pickit 2 with flowcode.
I do have a new laptop running Windows 10
I tried to even tried to download a Flowcode 6 program and it looks like the Compiler settings are part of my PC.
I have posted the Compiler messages and the program
I will add a few changes to my program hopping the Compiler works out.
John
Compiler Messages.jpg (51.28 KiB) Viewed 14135 times
PitcherMasterPICSep14.fcfx
(178.28 KiB) Downloaded 371 times
Hi John,
Have you read this post?
JLeith
Post by JLeith »
Hi Martin
I looked into the Post and it was a lot of data.
It was for Flowcode 3 & 4 and MLAB applications.
Back in the old laptop I was able to use my exact chip in flowcode and the same PicKit2.
I have the 10K battery on MCLR.
Now only difference between Windows 8 on the old laptop and the New Windows 10 is the way windows 10 has a directory 'Program 86" Which was not in Windows 8.
I have C:/program and the C:/Program 86
I see Flowcode is in Program 86 and Pickit2 in Program 86
I have tried and tried to find the settings for the Compiler & Parameters for Flowcode 6 to work with Pickit2.
Several forum conversations point to dropping PICKit2 and getting PICKit3. I don't see the need to go to PICKit3 when PicKit2 worked just 6 months ago.
I used Flowcode 6 & PicKit2 on the 1st project I built for the Master Keypad design. Only issue is I lost all my past 2yrs design and rebuilt the program with help of forum conversation with yourself and others when I posted the program.
John
JLeith wrote:It was for Flowcode 3 & 4 and MLAB applications.
No the post shows links to program chips directly using Flowcode 6
you will set at the start of the message:
medelec35 wrote:I successfully programmed a 12F1840 directly with Flowcode V6
I was refering to PICkit2
If you follow the links I posted, you will find two files.
One of them are the PICkit2 settings to load into Flowcode V6 and the other is an updated PICkit2 dat file to place in specified directory.
JLeith
Post by JLeith »
Hi Martin
I think I did it right.
I thought I would just try to do a Hex copy and not do a direct to chip.
Crash.
I googled and there was a issue with Flowcode and PicKit2 working in 64 bit windows 10.
Pickit2 Hex needed to be at ( PK2V023200.hex)
The file I got from your "This" I got the (PK2V023200.hex) Good news
Here is the current error when I do a Hex copy. Error 255
I also attached the images of the settings.
I'm at a loss as to the next steps I should take. It takes about 20min of seeing (..............) then the Error message.
I'm at a lost as to where I go now....
John :(
I have not used PICkit 2 before on my current version of 64 bit windows 10, so just changed target to the chip I have got (16F1937).
After loading FC6 with PICkit2.FCS found on the posted link, Chip programmed first time:
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
PitcherMasterPICSep14.c
Starting preprocessor: "C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\pp.exe" PitcherMasterPICSep14.c -i "C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\include" -d _PIC16F1937 -la -c2 -o PitcherMasterPICSep14.pp -v -d _BOOSTC -d _PIC16 -d _PIC16x -d _CHAR_INDEX
PitcherMasterPICSep14.c success
success
Completed BoostC compilation, return = 0
C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\boostlink_picmicro.exe  -ld "C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\lib" libc_16F.lib rand_16F.lib float_16F.lib "PitcherMasterPICSep14.obj" -t PIC16F1937 -d "D:\Flowcode testing" -p "PitcherMasterPICSep14" -swcs 6 2
BoostLink Optimizing Linker Version 7.20
http://www.sourceboost.com
Copyright(C) 2004-2013 Pavel Baranov
Copyright(C) 2004-2013 David Hobday
Warning: Recursion may cause call stack overflow in function:'FCM_Keypad'
Caution: argument of 'delay_us' calls must have a value of 1 or more
Caution: Delay inaccurrate: 'delay_us', Delay overhead:0ms, Unit delay:0.00101725ms, Delay resolution:1 units
Caution: Delay inaccurrate: 'delay_ms', Delay overhead:0ms, Unit delay:1.00016ms, Delay resolution:1 units
Warning unreferenced functions removed:
	 FC_CAL_Port_In__x	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_IO.c
	 FC_CAL_Port_Out__x	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_IO.c
	 FC_CAL_Port_Out_DDR__x	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_IO.c
	 Wdt_Delay_S	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_Delay.c
	 Wdt_Delay_Ms	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_Delay.c
	 FCI_DELAYINT_US	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_Delay.c
	 FCI_DELAYINT_MS	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_Delay.c
	 FCI_DELAYINTWDT_MS	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_Delay.c
	 FCI_DELAYINT_S	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_Delay.c
	 FCI_DELAYINTWDT_S	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_Delay.c
	 FCI_MIDSTRING	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_String.c
	 FCI_LEFTSTRING	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_String.c
	 FCI_RIGHTSTRING	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_String.c
	 FCI_TOSTRS16	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_String.c
	 FCI_TOSTRS32	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_String.c
	 FCI_TOSTRU16	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_String.c
	 FCI_TOSTRU32	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_String.c
	 FCI_TOLOWER	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_String.c
	 FCI_TOUPPER	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_String.c
	 FCI_COMPARE	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_String.c
	 FCI_FLOAT_TO_STRING	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_String.c
	 FCI_NUMBER_TO_HEX	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_String.c
	 FCI_STRING_TO_INT	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_String.c
	 FCI_STRING_TO_FLOAT	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_String.c
	 FCI_STRREV	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_String.c
	 FCI_STRMOV	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_String.c
	 FCI_SHEAD	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_String.c
	 isinf	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_Float.c
	 pow	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_Float.c
	 flt_round	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_Float.c
	 flt_floor	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_Float.c
	 flt_ceil	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_Float.c
	 flt_atan	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_Float.c
	 cos	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_Float.c
	 sin	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_Float.c
	 FCM_KeyTest	 in: D:\Flowcode testing\PitcherMasterPICSep14.c
	 FCM_Mos_Pitches	 in: D:\Flowcode testing\PitcherMasterPICSep14.c
	 FCM_tmr_service	 in: D:\Flowcode testing\PitcherMasterPICSep14.c
	 FCD_01211_CircularBuffer1__WaitForValue	 in: D:\Flowcode testing\PitcherMasterPICSep14.c
	 FCD_08c31_keypad_base__GetString	 in: D:\Flowcode testing\PitcherMasterPICSep14.c
	 FCD_03d91_led_base__TurnOn	 in: D:\Flowcode testing\PitcherMasterPICSep14.c
	 FCD_03d91_led_base__TurnOff	 in: D:\Flowcode testing\PitcherMasterPICSep14.c
	 FC_CAL_SPI_Slave_Uninit_1	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_SPI.c
	 FCD_01531_cal_spi__Prv_TextConsole	 in: D:\Flowcode testing\PitcherMasterPICSep14.c
	 FC_CAL_SPI_Slave_Init_1	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_SPI.c
	 FC_CAL_SPI_Master_Uninit_1	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_SPI.c
	 FC_CAL_SPI_SetPrescaler_1	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_SPI.c
	 FCD_06c41_SPI_Master2__SendString	 in: D:\Flowcode testing\PitcherMasterPICSep14.c
	 FCD_06c41_SPI_Master2__GetString	 in: D:\Flowcode testing\PitcherMasterPICSep14.c
	 FCD_06c41_SPI_Master2__UnInitialise	 in: D:\Flowcode testing\PitcherMasterPICSep14.c
	 FCD_04071_LCD__RAMWrite	 in: D:\Flowcode testing\PitcherMasterPICSep14.c
	 FCD_04071_LCD__Command	 in: D:\Flowcode testing\PitcherMasterPICSep14.c
	 FCD_04071_LCD__PrintFormattedNumber	 in: D:\Flowcode testing\PitcherMasterPICSep14.c
	 FCD_04071_LCD__ScrollDisplay	 in: D:\Flowcode testing\PitcherMasterPICSep14.c
	 FC_CAL_SPI_Slave_SetTxData_1	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_SPI.c
	 FC_CAL_SPI_Slave_GetRxData_1	 in: C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_SPI.c
Building CASM file
Memory Usage Report
RAM available:512 bytes, used:218 bytes (42.6%), free:294 bytes (57.4%),
Heap size:278 bytes, Heap max single alloc:79 bytes
ROM available:8192 words, used:7391 words (90.3%), free:801 words (9.7%)
success
Launching the programmer...
C:\Program Files (x86)\Flowcode 6\tools\PICkit2\pk2cmd.exe  -BC:\Program Files (x86)\Flowcode 6\tools\PICkit2\ -PPIC16F1937 -FPitcherMasterPICSep14.hex -M -A5 -R
|/-\|/- \ PICkit 2 Program Report
15-Sep-2018, 22:58:17
Device Type: PIC16F1937
Program Succeeded.
Operation Succeeded
FINISHED
Did you upgrade PICkit2 with dat file found here?
Hi John,
Sorry I have been extreamly busy so only been quickly brushing over the posts.
This is clearly wrong!
(214.48 KiB) Downloaded 3731 times
Looking at your screen capture (post error within a code box as is it's much better than screen capture) Flowchart is trying to compile with the wrong exe file instead of boostC!
What you need to do is:
Select Build, Compiler Options.
Select Import then load PICkit2.FCS
In the Setting click on the save icon:
(34.71 KiB) Downloaded 3731 times
A new box will appear.
Enter a name E.g PICkit2 Settings.
Delete the blank settings (Click on the icon, then select delete):
(19.65 KiB) Downloaded 3731 times
Make sure the new PICkit2 setting have the default box ticked!
The PK2V023200.hex is the new operating system for the PICkit2 programmer.
You need to use PICkit2 programming software (download from here) to load PICkit2 with a new operating system.
Select Trusted Download file 3.9Mb only
To do that, with PICkit2 connected, run the PICkit2 software, select Tools, Download PICkit2 Operating System.
You need to select the PK2V023200.hex file.
Hi John,
Have you made any progress since the last post or do you require further help?
JLeith
Post by JLeith »
Hello Martin.
Well almost made it I followed your steps to the letter.
I was able to get the Compiler to see the "PICkit2 Settings" under the Settings Name.
CRASH --- I did the PICKit2 upgrade using the "Hex" file. The Interface module updated and the world started to realign.
Now I can't see the PICKit2 Settings in Flowcode Compiler ?
It looks like when I did the Upgrade to the PICKKit2 from Version 2.50 to the New 2.61 the files under PICKit2 were erased.
Martin is the a web page to get a full upgrade for Pickit2 from 2.50 to 2.61
Or could you send me a ZIP file of the missing info for 2.61. Made I can add them back in.
John
JLeith
Post by JLeith »
Martin I was able to get the Pickit2 files structure back by using the V2.61 Zip file.
The file pk2cmd.exe is still missing.
Here is what I have back
1. The pk2cmd listing
2.The files in the PICKIT2v2 directory
John
This is the step of adding pk2cmd.exe
The file structure for PICkit2 directory
The PICkit2 will not be compiling (BoostC compiles) so you should not see pk2cmd.exe in the compiler tab.
You should only see pk2cmd.exe in the Programmer tab as it is used for programming only!
(39.89 KiB) Downloaded 3683 times
JLeith
Post by JLeith »
I missed that tab
Just so I have the correct settings. Still not working
Here is a picture of all the tabs.
On the "Compiler" Tab how do I get the values ?
John
(144.27 KiB) Downloaded 3681 times
(155.38 KiB) Downloaded 3681 times
(139.62 KiB) Downloaded 3681 times
JLeith
Post by JLeith »
Missed Compiler
Compiler is the spot I can't find the field values
John
(95.62 KiB) Downloaded 3681 times
Compiler settings should have loaded in when imported PICkit2.FCS
The settings I have are:
Compiler
pic\boostc\boostc_$(family:/12F/16F).exe
Parameters :
-v -t PIC$(chip:u) "$(target).c"
Linker/Assembler
$(appdir)compilers\pic\boostc\boostlink_picmicro.exe
Parameters :
-ld "$(appdir)compilers\pic\boostc\lib" libc_$(family:/12F/16F).lib rand_$(family:/12F/16F).lib float_$(family:/12F/16F).lib "$(target).obj" -t PIC$(chip:u) -d "$(outdir:~-1)" -p "$(target)" -swcs 6 2
Programmer
$(appdir)tools\PICkit2\pk2cmd.exe
Parameters :
-B$(appdir)tools\PICkit2\ -PPIC$(chip) -F$(target).hex -M -A5 -R
JLeith
Post by JLeith »
Hello Martin
Getting a little closer.
1st time with Error 1
John
(13.2 KiB) Downloaded 3675 times
I'm not sure how you imported PICkit2.FCS and the compiler field was blank, and now the settings are pointing to the project directory?? :?
One step at a time.
Re-import PICkit2.FCS .
Without changing anything, compile to target, then select the compiler messages and paste on here within a code box.
Screen captures leave things out.
Make it more difficult to see what the issues are.
JLeith
Post by JLeith »
What a mystery
I have imported the PickKit2.fcs
Not sure what you are asking me to capture ?
Martin can you make hex files form my projects and see if I can use the PICKIT2 to load the Hex files.
John
Team Pitch count 23 John_July 24.fcfx
(116.04 KiB) Downloaded 245 times
MasterPICSept14.fcfx
(178.28 KiB) Downloaded 300 times
JLeith wrote:Martin can you make hex files form my projects and see if I can use the PICKIT2 to load the Hex files.
It's best to get down to solving what the issue is.
After loading PICkit2.FCS and with PICkit2 connected to target that has power.
Just compile to chip.
When you compile to hex or compile to chip, there are compiler messages that are displayed.
For example the one I posted was:
success
Building CASM file
Memory Usage Report
success
Program Succeeded.
Operation Succeeded
FINISHED
What you do is Within the compiler messages when its finished click once so there is one like that changes to blue.
Press Ctrl A so all get highlighted, then press Ctrl C to copy.
Next on the forum post, just above the text box select Code then you will see code and /code but within square brackets.
After the inbetween ] & [ just paste then you should have something similar to above compiler message.
JLeith
Post by JLeith »
Off to get the info.
Confirmed I have power on the PIC
John
JLeith
Post by JLeith »
Error 1
Target folder: C:\Users\jleit\Desktop\PITCHC~1
Source name:   C:\Users\jleit\Desktop\Pitch Count\MasterPICSept14.fcfx
Title:
Description:
Device:        PIC.16F.16F1938
Generated by:  Flowcode v6.1.4.0
Date:          Tuesday, September 18, 2018 09:58:50
Users:         1
Registered to: Default Flowcode Name
Licence key:   EA6R55
http://www.flowcode.co.uk
Launching the compiler...
C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\boostc_16F.exe  -v -t PIC16F1938 "MasterPICSept14.c"
Launching BoostC...
BoostC Optimizing C Compiler Version 7.20 (for PIC16 architecture)
Single user Lite License (Unregistered) for 0 node(s)
Limitations: PIC12,PIC16 max code size:2048 words, max RAM banks:2, Non commercial use only
MasterPICSept14.c
Starting preprocessor: "C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\pp.exe" MasterPICSept14.c -i "C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\include" -d _PIC16F1938 -la -c2 -o MasterPICSept14.pp -v -d _BOOSTC -d _PIC16 -d _PIC16x -d _CHAR_INDEX
MasterPICSept14.c success
success
C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\boostlink_picmicro.exe  -ld "C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\lib" libc_16F.lib rand_16F.lib float_16F.lib "MasterPICSept14.obj" -t PIC16F1938 -d "C:\Users\jleit\Desktop\PITCHC~1" -p "MasterPICSept14" -swcs 6 2
	 FCM_KeyTest	 in: C:\Users\jleit\Desktop\PITCHC~1\MasterPICSept14.c
	 FCM_Mos_Pitches	 in: C:\Users\jleit\Desktop\PITCHC~1\MasterPICSept14.c
	 FCM_tmr_service	 in: C:\Users\jleit\Desktop\PITCHC~1\MasterPICSept14.c
	 FCD_01211_CircularBuffer1__WaitForValue	 in: C:\Users\jleit\Desktop\PITCHC~1\MasterPICSept14.c
	 FCD_08c31_keypad_base__GetString	 in: C:\Users\jleit\Desktop\PITCHC~1\MasterPICSept14.c
	 FCD_03d91_led_base__TurnOn	 in: C:\Users\jleit\Desktop\PITCHC~1\MasterPICSept14.c
	 FCD_03d91_led_base__TurnOff	 in: C:\Users\jleit\Desktop\PITCHC~1\MasterPICSept14.c
	 FCD_01531_cal_spi__Prv_TextConsole	 in: C:\Users\jleit\Desktop\PITCHC~1\MasterPICSept14.c
	 FCD_06c41_SPI_Master2__SendString	 in: C:\Users\jleit\Desktop\PITCHC~1\MasterPICSept14.c
	 FCD_06c41_SPI_Master2__GetString	 in: C:\Users\jleit\Desktop\PITCHC~1\MasterPICSept14.c
	 FCD_06c41_SPI_Master2__UnInitialise	 in: C:\Users\jleit\Desktop\PITCHC~1\MasterPICSept14.c
	 FCD_04071_LCD__RAMWrite	 in: C:\Users\jleit\Desktop\PITCHC~1\MasterPICSept14.c
	 FCD_04071_LCD__Command	 in: C:\Users\jleit\Desktop\PITCHC~1\MasterPICSept14.c
	 FCD_04071_LCD__PrintFormattedNumber	 in: C:\Users\jleit\Desktop\PITCHC~1\MasterPICSept14.c
	 FCD_04071_LCD__ScrollDisplay	 in: C:\Users\jleit\Desktop\PITCHC~1\MasterPICSept14.c
License restricted by the following files:
	MasterPICSept14.objRecompile the code with a less restrictive compiler license!
License exceeded by RAM: 662 bytes
License exceeded by ROM: 5384 words
You have reached the limit of the Lite License (Unregistered)
You can upgrade your license. Please visit: http://www.sourceboost.com
failure
FINISHED
JLeith
Post by JLeith »
Hello Martin
Only message I see a little different from your coppy
Your image stops after 7.20
JLeith
Post by JLeith »
This is odd
What License ?
failure
FINISHED
JLeith
Post by JLeith »
Never came across this message in building a project
Looks like this from the web page
Thoughts
(29.28 KiB) Downloaded 3645 times
