Simulation External Input Frequency
Docara
Has thanked: 28 times
Been thanked: 61 times
Post by Docara »
HI
Is it possible to expose the Simulation Input frequency so that I can dynamically change the value via a variable during runtime. If so how?
MAtt
Docara
Re: Simulation External Input Frequency
Post by Docara »
Anyone?
I had a quick go with the component as is and couldn't get it to work nicely so it looks like the component will need an update to allow it to do it. Should be easy to do so I'll try and have a go for you this afternoon.
I've added a new SetFrequency macro that allows you to set the frequency on the fly. Seems to work ok here for me.
I've pushed the new component to the Flowcode 8 update system now so it should be available.
Docara
Post by Docara »
Hi Ben,
Thank you so much that will help me know end - trouble is I'm running v7 could you publish the component here also?
Matt
Hi Matt,
Here is the updated component for v7.
sim_ext_input.fcpx
(2.74 KiB) Downloaded 296 times
Let us know how you get on.
Docara
Post by Docara »
Hi Ben,
Am I right in thinking this gets loaded into "C:\Program Files (x86)\Flowcode 7.2\components" ?
If so then I am afraid I cannot see where I can load a variable into the frequency box.
I have taken a screen grab of the Sim macro dialogue box so you can see
Matt
Hi Matt,
Whoops looks like I may have forgotten to expose the new Set_Frequency macro. I'll do that for you ASAP tomorrow.
Docara
Post by Docara »
Thanks Big Boy :D
Here we go, this should be right now.
sim_ext_input.fcpx
(2.82 KiB) Downloaded 253 times
