PIC16F689 timer2 compiling errors
Jörg Güldner
Has thanked: 17 times
Been thanked: 11 times
Post by Jörg Güldner »
Hello Matrix team,
compiling with the PIC16F689 is not correct working. I erased block to block and found out, that timer2 was the problem.
An empty program only with timer2 and the PIC16F690 compiles without errors. The same with PIC16F689 brings the errors back.
Can you have a look to this situation?
Thanks in advanced
Jorg
Has thanked: 481 times
Been thanked: 699 times
Re: PIC16F689 timer2 compiling errors
Hi Jorg,
I've just had a look at the datasheet and it seems that PIC16F689 does not have a Timer2
Leigh
Jörg Güldner
Hi Leigh,
you are right. I expected, that the fcdx-files contains the information for the choosed cpu.
So for future I can`t believe what flowcode presents in timers and interrupts. Is it right?
Best regards
Jorg
Hi Jorg,
The definition had a bug and the timer 2 options shouldn't have been there. I've removed the timer interrupt from the definition file now.
In most cases what is shown to you should be valid for your chip, we spend a lot of time going through device definitions, getting them correct and adding features but there are a lot of devices. If you find anything else that looks incorrect then let us know and we can solve the problem for you.
