Graphic display ssd1306 and esp8266 not working.
please give me the suggestion
test.c: 863: (1250) could not find space (100 bytes) for variable _FCL_COMMAND
test.c: 1825: (1250) could not find space (100 bytes) for variable _FCL_COMMAND
(908) exit status = 1
C:\Program Files (x86)\Flowcode 7\compilers\pic\bin\xc8.exe reported error code 1
FINISHED
pic 16f1939
Re: pic 16f877a
Hi, i also have same issue when compile HEX file ,i was connected with I2C communication with LCD display 16x2
need technical support
thanks
thanks
- My Sample I2C.fcfx
- (8.34 KiB) Downloaded 457 times
Re: pic 16f1939
Some components e.g. the ESP8266 have a variable buffer you can alter via the component properties to increase or decrease the RAM usage.
viewtopic.php?f=63&t=19743
If your fully up to date and still having problems then please can you post your compiler messages to the forums so we can see the error messages your receiving.
The error message is saying you have run out of RAM on your target device. You need to use less variables or switch to a device with more RAM available onboard.could not find space (100 bytes) for variable
Your program was compiling correctly for me using Flowcode 7. Are you using v7.3 and then applied the updates from here.i also have same issue when compile HEX file ,i was connected with I2C communication with LCD display 16x2
Re: pic 16f1939
http://www.flowcode.co.uk
Launching the compiler...
C:\Program Files (x86)\Flowcode 7\compilers\pic\bin\xc8.exe --chip=16F1939 "v2.c" --MSGDISABLE=359,1273,1388
Microchip MPLAB XC8 C Compiler (Free Mode) V1.41
Build date: Jan 24 2017
Part Support Version: 1.41
Copyright (C) 2017 Microchip Technology Inc.
v2.c: 897: (1250) could not find space (100 bytes) for variable _FCL_COMMAND
v2.c: 1859: (1250) could not find space (100 bytes) for variable _FCL_COMMAND
FINISHED
FINISHED
Re: pic 16f1939
The LCD in your program uses 1K of RAM to store the display buffer this could explain the higher than expected RAM usage. There could be an unbuffered version of the component you could use but this may limit functionality.
However first try reducing the size of the Wifi component's receive buffer and scan buffer properties. Maybe try the receive buffer at 200 or 100.
