Most PIC16LF1828 sold today are 7K program memory (some are still 4k), but the FCDX file or BoostC complier LIB restricts you to 4K.
Is there an updated file for this chip that allows 7K program? Or is there a work-around?
PIC16LF1828 FCDX file
Re: PIC16LF1828 FCDX file
Have you tried Flowcode 7 or 8? It doesn't use BoostC and so the compile limit has been removed.
You can use Flowcode 8 completely unlocked for 30-days for free if you want to try it out.
Are you confusing words with kB?
For example if you look a Farnell you will see that pic16F1828 has 7kB of flash memory.
However the datasheet shows memory as 4k words.
Therefore 7kB = 4k words
One is in bytes the other is words.
To convert words to bytes x 1.75
Since PIC microcontrollers has 14bit instruction words.
Reason for the 1.75 is 1 word = 14bits
= 14/8 bytes
= 1.75 bytes
I believe it is very unlikely the microcontroller have 4K in one batch and 7K in another.
It would be a manufactures nightmare that will use the microcontroller.
For example suppose they had 7K then accidentally got sent 4k and the memory used is 6K.
