Not sure why mu PortB wont trigger
JLeith
Has thanked: 146 times
Been thanked: 26 times
Post by JLeith »
I have my Halloween design working. My PortB0 trigger won't trip.
I have the PortB0 as a Logic 1 trigger state.
I have listed the PortB design and the Flowcode.
I suspect my Chip is not drawing enough current to register a logic 1 ?
I will take some readings at PortB0 and see what is registering.
John
Halloween Oct 27 2018.fcfx
(48.25 KiB) Downloaded 233 times
(10.64 KiB) Downloaded 1918 times
JLeith
Re: Not sure why my PortB wont trigger
Post by JLeith »
Found the Ghost in my program
When I switched to Interrupt on PortB0 I set Portb to 0
(32.41 KiB) Downloaded 1914 times
Problem Solved
John
Re: Not sure why mu PortB wont trigger
Nice one John,
Glad you have found the solution.
Yes turning interrupt input to an output does disable interrupt.
