i2C slave problems
davidkilshaw
Has thanked: 2 times
i2C slave problems
Post by davidkilshaw »
I have a recurring issue that i cannot solve. I am writing a piece of code to convert a byte of data received on i2c to set the mark space ratio of a PWM.
This is simple enough and i have written and proven all the code appart from the I2C slave part.
I have taken snippets of code from other projects on the Wiki (the LED slave sample code) and modified it to test what i am doing.
I attach the flowcode program i have written
The flashing LED's just show the status in various modes of the software.
I cannot get the software to jump to the point where it is accepting the address and loading the Byte of data
Any help greatly received
Dave Kilshaw
Has thanked: 481 times
Been thanked: 699 times
Re: i2C slave problems
You could try taking the delays out of the loop in the No branch.
However, it could be that we currently have problems with I2C on some PIC devices, currently being looked into.
davidkilshaw
The delays have been removed on previous versions
The LED has been set to off and then turned on if a valid byte is found but this also failed
The reason for the delays was purely to give visual indication (by speed of flashing) where the program was in execution
If this is a Bug in flowcode is there a time scale for a fix ?
Dave Kilshaw
davidkilshaw
Further testing on this project would indicate the the I2C interface with the 16F18325 isnt working properly
Setting the pic as a slave a master device sends a request to send data to the address of the micro i see the pulses on a scope as expected but i get no ack from the slave and by master reports no ack.
Swapping round and making the pic the master i see no pulses on the scope in any scenario.
This would indicate to me that the code has a bug (possibly indicated by Matrix as a bug in flowcode ?)
Has anyone managed to get this working not using Flowcode and writing in C ?
Hi Dave,
We are looking into the problem, hopefully the answer will reveal itself this week if not today. As soon as we have a solution we will let you know.
I spent some time on it yesterday and have found the problem but so far the fix is eluding me.
davidkilshaw
morning Benj
is there any update on this fix ?
Dave Kilshaw
Hi Dave,
I've spent the morning looking into this problem and think I have now got a bit further. The remappable I2C had a minor bug where the remap pins were not being defined 100% correctly. This should now be fixed in the I2C CAL component via the v8 Help -> Check For Updates menu.
Let me know how you get on.
davidkilshaw
Thanks for this. this has solved the I2C issue but i have found another issue which i wonder is if it is a mapping issue also
Reading port A4 into the micro and sending its digital level (0 or 1) to port C2 does not work
Reading port C0 into the micro and sending its digital level (0 or 1) to port C2 does work
It would appear that the micro isnt able to read port A4
could you have a look if that is an issue
Dave Kilshaw
Hi Dave,
Brilliant thanks for letting me know.
Please can you send me a simple program that shows this.
davidkilshaw
further investigation to whether physical ports on the micro can be programmed
So far i have tried to pulse on / off each port.
I can make ports A0,A1,A2,A3 (unknown as there is a pull up on my board) , C0, C1, C2,C3,C4 work correctly
Ports A4,A5,C5 do not work. And as stated i am usnsure about port A3 as there is a pull up external to the micro that i cannot remove.
This is for driving the ports with a high or low command in flowcode
I have not tried reading ports as this is more complex.
give me a shout if you can see the issue your end
thanks
Dave Kilshaw
davidkilshaw
benj
Here is the code that i used for the turning on / off each port. I initially did it to all ports at the same time (so had 12 output high macros macros and then 12 output low macros all set to different ports. The version uploaded is only doing one port as i was trying to see if there was cross mapping going on but there isnt.
davidkilshaw
the code for the read to write as mentioned in the first email is here
testing port a4 to led port c2.fcfx
(8.98 KiB) Downloaded 307 times
I think your config settings look a bit off.
You have the Clock Out Enable bit set to disabled, this actually enables the clock out bit so I have been through and changed the wording for this as it was a bit misleading.
You have the SOSC enabled as the main oscillator and this is on A4 and A5.
You also have low voltage programming enabled - this will likely also eat an I/O pin though not sure which one.
I'll get the new device definitions pushed out this afternoon.
davidkilshaw
Could you confirm what the clock settings insoftware oscillator mode mean specifically
i think i understand HFintosc 32Mhz is an internal osc at 32Mhz but does it tie up any pins ?
Extosc with 4* PLL i assume this requires a crystal connected to pins so will use up some of the pins
SOSC 32.768kHz not really sure what this is
LFintosc what frequency is this at
HDintosc 1Mhz i assume is a slower version of HFintosc. Does it tie up any pins
ExtOSC how many pins has this used.
On the general options page where you select the clock speed. Does this override any of the above setting for speed ?
Dave Kilshaw
Hi Dave,
I'm basing the following on a 16F18325.
No, But frequency will fluctuate slightly with temperature and pressure.
Yes OSC1 and OSC2 associated pins
Secondary Oscillator, again uses 2 pins SOSC1 and SOSC2 and often used to drive internal RTCC module.
On your device it's 31KHz. Another option to drive the RTCC or super low power applications. Again will fluctuate.
No
I beleive this uses OSC1, you can optionally have clock out on OSC2 depending on an additional config setting which is 1/4 of the rate of OSCIN.
davidkilshaw
great thanks for the update
