This is defined as a function calling itself within it's own definition - and lends itself to some very elegant functions..
It is used where a problem can be solved for a subset of the current problem and the problem can be split and solved for some simpler part(s) of the problem . So for example, the Fibonacci number (each number in the sequence is the sum of the previous 2) - Fib(n) can be defined as
Fib(n) = Fib(n-1) + Fib(n-2)The Radio4 puzzle for Today - today ('Seven diners sit down to eat seven different dishes at a Chinese restaurant. Unfortunately, everyone is served the wrong dish - but the circular table can rotate. Is it always possible to rotate the table so that at least two diners have the correct food?') - led to thinking about permutations (Permutations and Combinatorics are a large and fascinating area of maths/programming)
Can Recursion be used in Flowcode?
Yes it can
Generates permutations of an array and outputs them to UART. To do something more useful add code (or a macro call) to Permute. Notice that the first part of Permute tests for an end case - ending the recursion, and stopping the MCU crashing.
Notice also that I use a global array (and it's size) to permute - rather than passing it to the Permute macro as a parameter. This reduces the stack use - and allows a greater level of recursion on an MCU with limited stack space. An array of n digits has n! (factorial) permutations - so numbers get large fast. 6 -> 720, 10 digits -> 3628800 permutations.
So - the puzzle is left for you to enjoy (is the brute force approach the best one??)
Generating the Fibonacci sequence is left as an exercise - though Recursion is not a good way to generate them! Use a loop!
Note that a recursive solution can always be converted to a non-recursive function - although it often leads to much shorter and more elegant solutions.
Notes - on the ZX Spectrum I used to allow for up to 10! combinations as a maximum. I used to use a non-recursive algorithm (adjacent-mark) - which I haven't been able to find (if anyone has any info) - the recursive algorithm here I first saw in Wirth's 'Programming in Modula-2'. Now in C++ the 'next_permutation' STL algorithm is very useful.
Another 'easy' algorithm to code as a recursive macro is factorial (Factorial(n) = n * Factorial(n-1), with Factorial(1) = 1 as the end condition) - again a loop is quicker...
