Is there a limitation on the length of the filename of a Flowcode program?
I saved my program, renamed it and since it does not compile (with this cryptic massage), while the old (identical) program with a shorter name compiles without error.
PicPLC Liftbesturing V19C FC6 MONO, EMOD en Kollmorgen Mono PIC18F4520 2018-11-16.c
Starting preprocessor: "C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\pp.exe" "PicPLC Liftbesturing V19C FC6 MONO, EMOD en Kollmorgen Mono PIC18F4520 2018-11-16.c" -i "C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\include" -d _PIC18F4520 -la -c2 -o "PicPLC Liftbesturing V19C FC6 MONO, EMOD en Kollmorgen Mono PIC18F4520 2018-11-16.pp" -v -d _BOOSTC -d _PIC18 -d _CHAR_INDEX
PicPLC Liftbesturing V19C FC6 MONO(1): error: failure
failure
Completed BoostC compilation, return = 1
C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\boostc_18F.exe gerapporteerde foutcode 1
Limitation on length of filename?
Re: Limitation on length of filename?
Hi.
It's no so much about the filename length but what characters are used.
Try removing the comma and recompile.
