Scada software
Roy Johnston
Flowcode V4 User
Has thanked: 2 times
Been thanked: 34 times
Scada software
Post by Roy Johnston »
I have a board that used enc28j60. i am currently using Ms access visual basic to control this board. it works with no problems.
when i try using your scada software I am unable to send and receive from this card.
I programmed a set of leds to check functions of the board.
I can connect and open a socket however when trying to send and receive data it fails on the pointer.
I have attached both flowcode projects . please help I simply don't know how to get it to work.
scada.fcfx
(35.45 KiB) Downloaded 238 times
Flowcode1.fcsx
(10.89 KiB) Downloaded 252 times
Re: Scada software
Maybe try the socket open before the connect in the SCADA Flowcode1 project. Leigh's your man for this but this seems to be what we're doing in our code.
Roy Johnston
Flowcode V4 User
Re: Scada software
Thank you,
I made the changes , it behaves exactly the same.
arp request is ok
open socket and connect is ok .
as soon as we send the data it fails. the inbound DataPointer = 0
scada.fcfx
(35.45 KiB) Downloaded 277 times
Flowcode1.fcsx
(11.17 KiB) Downloaded 274 times
Has thanked: 481 times
Been thanked: 699 times
Re: Scada software
This could be due to a faulty TCPIP.DLL
Could you check the size of the TCPIP.DLL in C:\ProgramData\MatrixTSL\FlowcodeV8\Components\dll
Right click, Properties->Details
Latest working version is 98.5KB, faulty one is 98.0KB
Looks like there is the possibility that the 8.1 full installer has the correct DLL, but the patch might not
Re: Scada software
We've fixed this now (hopefully), the DLL and TCPIP Base component got out of sync, there's a new auto update to fix it :)
Your DLL will most likely be correct, just an update for the TCPIP Base component.
Leigh
Roy Johnston
Flowcode V4 User
Re: Scada software
Thank you.
will try again today and revert back to you.
Roy Johnston
Flowcode V4 User
Re: Scada software
Thank you,
working now.
