using eb038 with flowcode 8
SimonCaruana
Post by SimonCaruana »
Hi there,
anybody knows when i can find the relay board eb038 in flowcode 8 please?
thanks
Simon
Re: using eb038 with flowcode 8
Hi Simon,
A Relay board component is not required in flowcode.
The relays are only activated when the output connected to EB038 goes high.
Have the patch in low nibble for portx 0 to 3
Or high nibble for portx 4 to 7
x = whatever port you select and so long as microcontroller supports it. e.g port C
You can use LED components or outputs.
For example you can choose LED Array and change count to 4 within properties.
Make sure the jumper on the relay PCB is on low nibble.
SimonCaruana
thank you very much sir
You're welcome.
Let us know If you're still having any issues.
