When i click on FlowcodeV8.exe, he don't run just send me a message (in a picture) .
Can you help me please. (sorry i'm french so the screen too)
Probleme running FlowcodeV8.exe
- error message
- (11.08 KiB) Downloaded 1484 times
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Probleme running FlowcodeV8.exe
Bonjour.
La recherche suivante peut aider:
https://www.google.co.uk/search?q="car+ ... te+à+côte"
par exemple:
https://eu.community.samsung.com/t5/Sma ... d-p/201719
J'espère que ça aide.
Steve.
par exemple:
Steve.
Thank you ^^
What Microsoft Visual C++ Redistributate is used by flowcode 8 please ???
It's probably the solution to resolve my problem ^^
Hello Vr69,
Sorry to hear about your problem. You should not need to install any VC++ Redistributable for Flowcode 8. But you can try Visual C++ 2015 Redistributable (x86 version).
https://www.microsoft.com/en-us/downloa ... x?id=52685
Are you running an anti-virus or software for system maintenance? It is possible that these are interfering with Flowcode or the installation.
Daniel.
Daniel.
When i try to install this, he say "error, it's already install on".
My antivirus is disable and let acces to flowcode 8.....
I would suggest that you uninstall Flowcode 8. And then restart your PC into safe mode following this guide.
https://support.microsoft.com/en-gb/hel ... -safe-mode
When in safe mode, install Flowcode 8 again, and try running it (still in safe mode). If this works, it is likely that external software (such as an antivirus) is interfering.
Daniel.
Daniel.
