Comparator PC10f204
luibra63
Has thanked: 3 times
Been thanked: 6 times
Comparator PC10f204
Post by luibra63 »
Hi all
I use a PIC10F204 for a simple project.
I need actived a led when the voltage at the pin GP0 is major at the 06V, internal refernce voltage at the comparator.
I read that the flowcode not simulate the internal comparator, is correct?
when I tried at connect a potentiometer at pin GP0 for simulate,is not was possible, why?
i tried set a comparator with C code, is it possible?, and the internal register, for example "CMCON0" is simulated in flowcode?.
for this simple project I can programmer in assembly code, but I would like tried wìth flowcode. thankyou for your advises and sorry for my bad english.
I attack an example
pic_comparator.pdf
(196.33 KiB) Downloaded 270 times
Re: Comparator PC10f204
Currently Flowcode doesn't support internal comparator modules. If you want to use them you have to use your own C code inside C icons to drive the peripheral registers. We have tried a number of times to include comparators but they differ so much from device to device that it quickly gets very complicated.
The ADC components require an ADC peripheral and an ADC capable input pin. The 10F204 has neither of these features just a comparator.
The C code icons won't simulate, they will be ignored by the simulator. However they will compile and work on the target device.
You are very welcome and your English is very good, both clear and understandable :D
luibra63
Post by luibra63 »
Thanks Benj
All is clear, I'll try tomorrow.
Flowcode is very good, I'm not a programmer, I'm hardware specialist, and flowcode for me is perfect for realized a my Christmas project.
only question, exist one list of command "C" code correct or different for flowcode?,
for example,
tes_bit , set_bit ecc.
thankyou very much
For general purpose bit manipulation using a C code icon you can call these functions.
set_bit(var,bitno) 	//Sets a single bit
clear_bit(var,bitno) 	//Clears a single bit
test_bit(var,bitno) 	//Tests a single bit
for example
set_bit(FCV_MYVAR, 0);
Will set bit 0 in the MyVar Flowcode global variable.
For more specific register manipulation on a PIC device where you want to specifically reference a bit in a register by name you can also use these functions.
st_bit(var,bitno) 	//Sets a register bit
cr_bit(var,bitno) 	//Clears a register bit
ld_bit(var,bitno,val) 	//Loads a register bit as a 0 or 1
ts_bit(var,bitno) 	//Tests a register bit and returns true or false
for example
cr_bit(TRISA,TRISA0);    //Convert Port Pin A0 into an output
st_bit(PORTA,RA0);     //Set output pin A0 high
You can refer to the device datasheet for the register names and bit names.
STibor
Has thanked: 116 times
Been thanked: 113 times
Post by STibor »
Hello!
I attach an example.
Not tested in hardware.
COMPARATOR_10F204.fcfx
(9.58 KiB) Downloaded 321 times
luibra63
Post by luibra63 »
thanks Bengj, very good.
thanks Stibor, fantastic, but for me is difficult, I am only harware man and software is devil for me. :twisted: :twisted:
Anyway I want to understand to try
best regards
luibra63
Post by luibra63 »
I tested firmware send from STibor, perfect funcionally, I changed only configuration pin "CIN-" because I used internal reference value.
For me is very important understend "C code" icon, your example is very exaustive.
Thankyou very much
