Text buttons phantom
Ferla
Flowcode v5 User
Been thanked: 19 times
Post by Ferla »
I purchased FC8, but I have a problem with text display macro components. Also the Icons bar can not move to the left side, remains fixed at the top
Pc win7 64bit
Ram 8Gb
screen resolution 1366X768
Ferla
Not Buttom.jpg (53.2 KiB) Viewed 2907 times
Ferla
Flowcode v5 User
Re: Text buttons phantom
Post by Ferla »
I found out that it is caused when the Italian language is invoked. You can correct it? I have to put in a new fix
Ferla
DanielM
Has thanked: 11 times
Been thanked: 22 times
Post by DanielM »
Dear Ferla,
My sincerest apologies for this. I'm please to say I've fixed the issue with the dialog and it was due to a fault during the translation to Italian.
Please download the following zip, and extract its contents to the "languages" subfolder inside your Flowcode v8 install folder (usually found in "C:\Program Files (x86)\Flowcode v8\languages"), overwriting the existing FlowITIT.dll file inside that folder.
FlowITIT.zip
(700.5 KiB) Downloaded 229 times
Regarding the icon bar: This was a recent deliberate decision to bind the icon bar to each programming view, in order to try and make it more obvious for beginners. The next patch for Flowcode v8 will include the ability to use the old style of icon bars if you wish. Currently, Flowcode will place the icon bar at the top if it detects that you are using a monitor with a very low vertical resolution (I think the cutoff value is 800 vertical pixels), in order to display as much of the bar as possible.
I hope that this has helped.
Kind regards,
Daniel
Ferla
Flowcode v5 User
Post by Ferla »
Thanks Daniel, no problem, I try this evening. :wink:
Ferla
