Simulation only: the Baud change value displayed within Console is incorrect:
Using ChangeHWBaud to 3 should display within Console 9600 and not 4800.
Harware TX is working as expected at the correct 9600 baud rate.
Hardware: Target device 16F18877 Setting Channel 1 RX interrpt to remap pin C4.
Rx interrupt appears not to work, will do further tests tomorrow.
UART PIC8
Re: UART PIC8
Hi Martin,
Many thanks for letting us know. I have now solved the problem and added the fix to the update system.
Hopefully it solves the issues you're having.
