How to save ULong variable value in EEPROM?
kg300
Has thanked: 5 times
Post by kg300 »
Hi, I want to save a Ulong Variable (06 digits) in EEPROM, any example for me.?
I get a code from Arduino forum, writing in the eeprom memory locations is ok, but when i tried to get back data from these locations variable only show the value less then 65000. mean only get back Unint value from eeprom. any help pleas...
long EEPROMReadlong(long address) {
long four = EEPROM.read(address);
long three = EEPROM.read(address + 1);
long two = EEPROM.read(address + 2);
long one = EEPROM.read(address + 3);
return ((four << 0) & 0xFF) + ((three << 8) & 0xFFFF) + ((two << 16) & 0xFFFFFF) + ((one << 24) & 0xFFFFFFFF);
void EEPROMWritelong(int address, long value) {
byte four = (value & 0xFF);
byte three = ((value >> 8) & 0xFF);
byte two = ((value >> 16) & 0xFF);
byte one = ((value >> 24) & 0xFF);
EEPROM.write(address, four);
EEPROM.write(address + 1, three);
EEPROM.write(address + 2, two);
EEPROM.write(address + 3, one);
Re: How to save ULong variable value in EEPROM?
Maybe try this instead.
Read
byte four = EEPROM.read(address);
byte three = EEPROM.read(address + 1);
byte two = EEPROM.read(address + 2);
byte one = EEPROM.read(address + 3);
return = one
return = return << 8
return = return | two
return = return | three
return = return | four
Write
byte four = value;
value = value >> 8;
byte three = value;
value = value >> 8;
byte two = value;
value = value >> 8;
byte one = value;
kg300
Post by kg300 »
Its working ok. thanks Benj :D
Sashinda
Post by Sashinda »
hi,
How to write this in calculation block?
EEPROM Read;-
return = one
EEPROM Write :-
byte four = value;
value = value >> 8;
byte three = value;
value = value >> 8;
byte two = value;
value = value >> 8;
byte one = value;
Please help me...
Hi Sashinda,
Welcome to the forums.
I have attached a flowchart that works the way Ben suggested.
I have also included two alternative ways of saving and retrieving ULongs(disabled icons).
Store & Retrieve ULong within EEPROM v3.fcfx
(14.77 KiB) Downloaded 294 times
Sashinda
Post by Sashinda »
hello...Medelec35
It's working super... :D
Thanks a lot. :)
I will never forget your help...
Hi Sashinda ,
You're welcome.
I'm pleased you have your project working super.
Thank you for letting us know, really appreciate it.
AbhijitR
Has thanked: 284 times
Been thanked: 80 times
Post by AbhijitR »
Hello! Martin
Many thanks for this post, you are too good.
medelec35 wrote: ↑
Wed Sep 02, 2020 5:11 pm
Finally I got the opportunity to thank you.
Abhi
