Flowcode8 i2c slave functionality
davidkilshaw
Has thanked: 2 times
Post by davidkilshaw »
When using the i2C slave macro I am unsure if the following occurs
When the pic is set to an address and that address is sent via the master device does the pic respond with an ACK after it has received the address?
Has thanked: 481 times
Been thanked: 699 times
Re: Flowcode8 i2c slave functionality
You need to read the Slave Status (e.g. in Main loop)
If it indicates that an address has been received then call Slave_RxByte with Last set to 0 to Ack it.
I've attached (a rather old) example.
Hope that helps
Leigh
I2C Slave LEDs.fcfx
(6.7 KiB) Downloaded 225 times
