Can I integrate an Arduino sketch into Flowcode?
MJU
Has thanked: 121 times
Been thanked: 108 times
Post by MJU »
I have the C-code simulation component and pasted a piece of an Arduino library into it.
When I compile it, it doesn't generate errors.
Does it mean that I can use this library in Flowcode?
Maybe I'm missing something, but I was wondering... :-)
I got this library: "RadioHead" from https://learn.adafruit.com/adafruit-rfm ... rfm9x-test
and my hope was to use it in Flowcode.
Or don't I get the purpose of the C-code. Or is the library not standard C-code?
If I can use it, what steps do I need to do to use especially this library in Flowcode?
Has thanked: 481 times
Been thanked: 699 times
Re: Can I integrate an Arduino sketch into Flowcode?
Using Arduino libraries within Flowcode is extremely tricky for a number of reasons,
not least that the code is C++, interfaces use structures, rely upon Arduino port settings, and libs are generally dependent upon other libs
So the best advice at present is to take a look at the Arduino code, see what it does, and try to replicate that in Flowcode icons.
Leigh
