RTC - Serial EEPROM dspMIAC
gavo4
Been thanked: 8 times
Post by gavo4 »
Hi Leigh,
Happy New Year!,
I have the RTC MCP794 and the Serial EEPROM on the same Channel and Pins for the SDA and SCL, I know the two can work together but somehow I can't seem to get them to work together even though they are in separate routines and not call simultaneously, do you have any ideas?
Gavin
Has thanked: 481 times
Been thanked: 699 times
Re: RTC - Serial EEPROM dspMIAC
Hi Gavin,
You are right, the EEPROM does not work when RTC is used, I'm looking into it.
btw. What version of Flowcode do you use? V8?
Leigh
Hi Gavin,
Please drop this fixed component into your directory,
\ProgramData\MatrixTSL\FlowcodeV8\Components
(auto update not currently functional)
Leigh
serial_eeprom.fcpx
(16.84 KiB) Downloaded 449 times
gavo4
Post by gavo4 »
Hi Leigh,
I am using Flowcode v8.1.11..;-)
Gavin
gavo4
Post by gavo4 »
Hi Leigh,
I updated and replaced the file in:
C:\Program Files (x86)\Flowcode v8\DefaultData\FlowcodeV8\Components
I assume this is correct?
Gavin
Hi Gavin,
No, that's the directory where Flowcode keeps the default installation files.
You need to drop the new component into
C:\ProgramData\MatrixTSL\FlowcodeV8\Components
nb. C:\ProgramData is usually hidden by Windows
You might need to enable the viewing of hidden files and directories,
don't ask me how to do that, I hate Windows :lol:
Leigh
gavo4
Post by gavo4 »
Ah thanks for the help Leigh!,
Works like a charm!
To make life easier,
I have got a shortcut of the FlowcodeV8 hidden directory on my desktop.
To do that paste in windows explorer
Then right click on FlwocdeV8 and select Copy address:
(43.27 KiB) Downloaded 2159 times
Finally, right click on your desktop and select Paste Shortcut.
Then its always handy for when you have to manually update component or fcdx file.
