Expansion Modules dspMIAC
gavo4
Been thanked: 8 times
Post by gavo4 »
Hi Leigh and Benj,
Happy New Year!,
Can you please advise where I can find info on the expansion modules and how to integrate them with the dspMIAC?
Many Thanks,
Gavin
Has thanked: 481 times
Been thanked: 699 times
Re: Expansion Modules dspMIAC
Hi Gavin,
Thanks, all the best!
To use MIAC expansion (addon) modules you need to select
Project Options->MIAC (dsPIC) System
Then add a "dsPIC MIAC" to the panel
Then add MIAC Addon modules to the panel
I've attached a simple example.
This might help
https://www.flowcode.co.uk/wiki/index.ph ... on_Modules
Leigh
dsPIC MIAC system.fcfx
(9.82 KiB) Downloaded 441 times
gavo4
Post by gavo4 »
Thanks Leigh!
gavo4
Post by gavo4 »
Hi Leigh,
I assume these modules are connected via the CAN Port L and H?
Gavin
Hi Gavin,
Yes, that's it, use the CAN connections on hardware.
The LED flash test will prove it's all connected correctly :)
Leigh
gavo4
Post by gavo4 »
Thanks Leigh,
Works like a dream!...;-)
Gavin
