PIC16F877A-PWM Output x 2
KrisJeff
Flowcode v5 User
Has thanked: 4 times
Post by KrisJeff »
I require 2 PWM outputs from my 16F877A. I can simulate OK but the chip only outputs to PWM-1 I realize that you can assign the PWM outputs to the pins require but I just cant understand how? In properties I can highlight the pwm_pin and nothing comes up to confirm the pin? Also can expose but again it doesn't seem to do anything? It's driving me bonkers. I thought that enabling each PWM it would output to both PWM pins. However, although simulating OK it only outputs to the one PWM outhttp://www.matrixtsl.com/mmforums/download/fil ... d=28363put (CCP1)?
PWM_fader16F877A O&C.fcfx
(15.82 KiB) Downloaded 314 times
Re: PIC16F877A-PWM Output x 2
The Channel property allows you to map the peripheral the component will use the generate the PWM signal. The pin propery simply shows the pin used by the selected peripheral. If only one channel exists then your target device only has one PWM peripheral on-board.
You can use software to generate PWM using for example a timer interrupt if you do not have enough hadware channels on your device.
Hi KrisJeff,
If you look at the properties of the PWM components on 2D panel:
(259.56 KiB) Downloaded 1027 times
You can see that PWMs are both set to Channel1 and frequencies are different.
Also, You can see in the properties the pin PWM output should appear on.
You need to set PWM2 to Channel2:
(24.1 KiB) Downloaded 1027 times
and make sure the period overflow and prescaler are matching on both channels.
KrisJeff
Flowcode v5 User
Post by KrisJeff »
Dear medelec,
Thank you. I'm new to version 8. My properties panel was not set wide enough so I could only see the left column? What a plonker?
Thank you so much. :D
You have not used Flowcode before so an easy mistake to make.
Within the Learning Centre You will find a useful Introduction to Microcontroller Programming course.
Although created using V7, It should be compatible with V8.
There are plenty of training videos as well.
Thanks for letting us know issue is resolved.
