Add Rotate for 2D and 3D panels [Resolved]
I would like to be able to enter a rotation angle rather than drag a component or object by 45 or 90 degrees for example.
If not used rotating objects than rotation can be a bit of a pain.
chad
Has thanked: 27 times
Been thanked: 33 times
Re: Add Rotate for 2D and 3D panels
Post by chad »
Can't you already do that? Select a component, in properties>position the x,y,z rotation?
Maybe I am missing something..
chad
Hi Chad,
Thank you for your reply.
I had totally forgotten I can do that. :oops:
I'm not a 3D person so don't normally require rotating components (Except for the occasional drag and rotate).
3D is a great feature, so need to get into it more.
