downloaded code running at 500Khz
gavin mack
Has thanked: 3 times
Been thanked: 3 times
Post by gavin mack »
Flowcode program runs fine on simulator, and when code is downloaded to 16f1937 using the 19Mhz external oscillator on eb-006.
modified the code to include the osccon code of 0x78 using intosc helper tool for 16Mhz, changed oscillator to internal in configuration and typed 16Mhz frequency in general options. moved clock jumper on eb-006 to ra6and7. see attached images for screen shots of settings. When revised code is downloaded to 16f1937 it runs as if the clock is set to 500Khz. flowcode program also attached.
(21.81 KiB) Downloaded 2028 times
(4.21 KiB) Downloaded 2028 times
TEST_10_INT_OSC.fcfx
(26.05 KiB) Downloaded 336 times
Re: downloaded code running at 500Khz
Hi Gavin,
Have you tried the one second flash test to determine actual speed as there could be an issue affecting your results?
E.g issue with inputs as that is setting the delay time.
Ok I have worked out your issue.
You have placed
OSCCON=0x78;
within commented out section.
So you need to use
  Enter C code below this comment
 OSCCON = 0x78;
instead of
 OSCCON = 0x78;
As you are correct.
Since OSCCON=0x78; is within commented out section, Hardware is running at the default 500KHz internal osc speed, since OSCCON code is being ignored.
Move it out and you should be ok.
gavin mack
Thanks for that Martin, it works fine
That's great,
Thanks for letting me know.
