Floating Points
gavo4
Been thanked: 8 times
Floating Points
Post by gavo4 »
Hi Leigh,
Hope all is well!,
I need some help with a floating point please..;-), somehow I can't seem to get the second decimal.(I get just .0)
I have a very simple routine look at an interrupt on the Standard PIC MIAC and I am using I8 with RB2
I have a calculation counting my pulses (working 100%),
I then have a calculation of a Floating Point dividing my pulses (count variable so I can see the exact litres like 2.5L when I get 5 pulses) and I then convert the floating point variable to a string showing a single decimal place. When I read 5 pulse I get 2.0 so something is not right,
Any ideas where I have gone wrong?, code attached..;-)
Gavin
Water_Meter_V1.fcfx
(15.56 KiB) Downloaded 411 times
mnf
Has thanked: 70 times
Been thanked: 440 times
Re: Floating Points
Post by mnf »
Hi Gavin,
It's the way C works. The problem is here:
- the calculation divides count by 2 - both integer values and then tries to convert the result ( integer 2) to a float.
The fix is easy - just change the 2 to 2.0 which will force the compiler to handle the calculation using floating point values..
gavo4
Re: Floating Points
Post by gavo4 »
Perfect - thanks Martin -
You are a champion and it works perfectly now..;-)
