RX interrupt works well until ChangeHWBaud is used.
After that RX stops working.
Attached is a simple demo.
Baud is 9600
5 x 'U' are sent to test TX side.
Set Terminal setting to echo chars.
Press a key on the keyboard (Except c) then chars should all be echoed to show RX int working.
Press c to make baud to change to 4800 then straight back to 9600.
Again 5 x 'U' are sent to test TX side.
Chars are no longer echoed.
As I'm changing name and pin codes in both HC05 and HC06 within same project.
It's vital that RXint works after ChangeHWBaud is used, since baud for HC05 must be at 38400 in AT mode.
BUG: ECIO40P8 ChangeHWBaud stops RXINT0 from working
- ECIO40P8 UART RX INT Test.fcfx
- (12.24 KiB) Downloaded 216 times
Re: BUG: ECIO40P8 ChangeHWBaud stops RXINT0 from working
Hi Martin,
Thanks for letting us know.
Hopefully I have now fixed this for you. The latest CAL UART file is now available via the update system.
Hi Ben,
No problem.
Thank you.
No problem.
Yes you have, working perfect.Benj wrote:Hopefully I have now fixed this for you
Thank you.
