From Light Sensor to Temperature Sensor?
JDR04
Has thanked: 111 times
Been thanked: 13 times
Post by JDR04 »
This is a program created some time ago with a lot of help from you guys. It used a phototransistor to detect light then switch a led on.
Would I be correct in assuming I can swap the phototransistor for a thermistor and the same program can be used? Thanks a lot.....John
Auto Light 1.1.fcf
(9.5 KiB) Downloaded 452 times
Re: From Light Sensor to Temperature Sensor?
Hi John,
Yes that should work fine :D
