Cal UART SendNumber
Cal UART SendNumber
Can the Cal UART SendNumber be changed from Unit to Long so it matches standard UART?
I'm currently changing the UART to CAL UART in my project and need to send long values.
Currently as there is a mismatch between the two.
Thank you.
Re: Cal UART SendNumber
Is this a quick change,
or is there a lot of work involved?
Sorry for the bump.
I need to create a component ASAP.
Hi Martin,
Not in the office today but try this and it should hopefully do what you need.
cal_uart.fcpx
(56.12 KiB) Downloaded 192 times
Thanks Ben,
Working perfect!
Exactly what I wanted.
