Exit Loop after push button
Monie Jacobsen
Has thanked: 17 times
Been thanked: 46 times
Post by Monie Jacobsen »
Hi everybody
How to leave the Loop below and continue?
Exit Loop.JPG (29.03 KiB) Viewed 18377 times
It does not help by pressing the Miac dsPIC KetPad button (8)
See attached file:
MIAC_dsPIC_ClockQuit KeyPad.fcfx
(36.27 KiB) Downloaded 543 times
Best Regard
Monie
Re: Exit Loop after push button
Hello Monie,
I take it you are updating the GetKey variable inside the loop. Looking at your program you are sampling the keypad but saving the result into the variable Key.
Maybe try this instead in the loop parameter.
Key <> 8
Hi Monie,
You have assigned a variable called Key to the GeyKey component.
However the variable you are checking within the loop to exit is called GetKey
You need to change one of the variables so they match.
Edit.
Ben beat me too it.
Monie Jacobsen
Hi medelec35 and Benj
Thanks for your suggestions;-)
Can't get out of this loop.
Even if I use it GetKey <> 8
Best Regard
Monie
Key <> 8
Monie Jacobsen
Hi Benj
I can't get out of LOOP
Even if I try what you write...
Best Regard
Monie
The way your Flowchart is set up, with no key pressed or any key except 8, it should not loop anyway.
It should only loop If you hold down key 8.
Could there an issue with one of the call macros?
You could try disable all then enable one at a time?
Unfortunately, I have not got a dsPIC to test with.
Monie Jacobsen
Hi medelec35
Don't Write Key <> !8
But this works Key <> 8
So now I can get out of LOOP and work on the codes.
You both have to thank you very much for your help.
Best Regard
Monie
Monie Jacobsen
Hi everybody
How to convert TimStr and MiniSter and SecStr
Have tried but not succeed!
I want to convert String to Float, must use Float format!
Must use HOUR FP and MIN FP and Sec FP... FLOAT format
Do you have a suggestion?
HOUR_FP = StringToFloat$ (TimeStr)
MIN_FP = StringToFloat$ (MinStr)
Sec_FP = StringToFloat$ (SecStr)
See attached file below!
MIAC dsPICSetting SolarTracker.fcfx
(137.67 KiB) Downloaded 486 times
If you have a proposal then I will be very happy;-)
Best Regard
Monie
Hi Monie,
Replied here.
viewtopic.php?f=28&t=20979#p94032
