Once again I come here humble to ask for your kind help
I started to play around with Modbus...my final target will be to have a pc as master and read various PICS loaded with sensors, so far so good!
So as a flowcode 8.1 user I searched flowcode website and found
Modbus TCP Master component
https://www.flowcode.co.uk/wiki/index.ph ... s:_System)
Great, so I start trying to make it work I simulation but nothing the 2 instances of flowcode don't communicate with each other...
I also tried adding network comms for Modbus TCP to make the communication but...nothing.
Now I am thinking that I have a few pic18f46k80 and a few enc28j60 maybe I can try real time??
The main question is, is there a Modbus TCP/IP master/slave example using the simulation or enc28j60 that is tested and works?
Because I searched a lot and couldn't find anything!
Thank you very much!!!
