Hi there,
I'm using a EB006009 Board with a PIC16F1937 for a university project, but am struggling to get it to work with mLoader on my laptop.
I've followed all the other troubleshooting steps I could find online, e.g. reinstall correct driver, use different USB port etc. but nothing is helping. I've attached images of the driver version, mLoader errors etc. The CSV file error occurs anytime chip autodetect is used.
Thanks,
Dan
Trouble using an EB-006-00-9 Board with mLoader V4.0.0.1
- (80.14 KiB) Downloaded 2574 times
- (42.23 KiB) Downloaded 2574 times
- (19.01 KiB) Downloaded 2574 times
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Re: Trouble using an EB-006-00-9 Board with mLoader V4.0.0.1
From the looks of it, it seems like the relevant csv data files arent present with mloader.
In the same directory as the mloader executable there should be some CSV files, one of them should be "8bConfigData.csv", this one contains the data for the 16F1937.
jasonpraful
I have checked for all the relevant files, tried running mloader as an administrator and it still doesn't work.
Please find the image below showing the relevant files. Please help ASAP.
tried all steps possible, yet doesnt work.
- (177.69 KiB) Downloaded 2495 times
It looks like mLoader cannot see the E-block device. The orange circle should turn green.
Maybe try uninstalling the device from device manager and including the driver in the uninstall. Then install our USB driver from here.
https://www.flowcode.co.uk/old_site/resources/get ... php?id=744
Finally unplug and replug the EB006 and hopefully it should work correctly now.
jasonpraful
I have all the necessary drivers installed, yet doesnt work,
Please find screenshot below showing all the EB006 being detected by the computer.
Please let me know how i can fix this issue.
- (30.4 KiB) Downloaded 2471 times
- (80.69 KiB) Downloaded 2471 times
Please can you try running mLoader with admin permissions and see if this makes any difference?
Is this your home PC or is it a locked down College/Uni PC?
Dr T JONES
- Been thanked: 1 time
Did you resolve the problem? I have exactly the same issue with the same images of files etc you had but am using a new eblocks2 Bl0080 board
