ESP8266 Initialise Macro and MCU Restart Problems (ATMEGA32u4)
celebriums
Has thanked: 71 times
Been thanked: 33 times
Post by celebriums »
Hi All
1. In the software;
There is no problem when I communicate with AT commands via ESP8266.
The AT command works fine.
2. In the software;
When I use the Initialise function of ESP8266, the program stops and the processor restarts.
In startup function, there is a problem, it does not work correctly.
You can see this in the video.
https://youtu.be/Rwr_1W7zAQ0
ESP8266_Test.fcfx
(25.39 KiB) Downloaded 256 times
ESP8266_AT_Commands.fcfx
(27.21 KiB) Downloaded 259 times
Sincerely Regards
Sadık SUME
www.kaandesign.com.tr
