Hi guys,
OK if I send a ZERO to a Port pin then want to clear that ZERO after a delay, I have been sending a ONE to the Port pin.
How can I clear the Port without sending the ONE?
I have tried to INPUT the Port to a VARIABLE (that I then reset to ZERO next instruction) to clear it but it has gone weird.
So without sending the ONE after the ZERO how do I clear the Port to wait for my next ZERO.
Thanks in advance...
James :-}
Someone Please Help
Re: Someone Please Help
Hi James,
So you're sending 0 to set the port at 0V (logic 0)
When you say clear do you mean you want the port to go back to 5V (logic 1) after a set time, or to an input?
Can you post a flowchart that clears with sending a 1 so I can work out what you want to do.
Sorted it out. Just needed to send a 2 microsecond pulse of a 1 and that worked - not exactly what I needed to do but it worked.
What I was trying to do was sort of stop the 0V so it acted as a pulse to mimic a pushbutton switch then went back to where ever it had been voltage wise as it had been before the button was pressed if you get me.
