Modebus Slave Help!
seokgi
Has thanked: 18 times
Been thanked: 16 times
Modebus Slave Help!
Post by seokgi »
Hi!
I am making a MODBUS Slave program using RS-485.
I edit the incoming data to the RS-232 and put it in the Modbus Slave address, and then take the data through RS-485 from another SCADA program.
I tried several examples and it does not work.
I need help.
I upload a program I made. I do not know what went wrong.
I always appreciate your help.
PRT2COM_Test1.fcfx
(21.47 KiB) Downloaded 199 times
viktor_au
Has thanked: 45 times
Been thanked: 63 times
Re: Modebus Slave Help!
Post by viktor_au »
Hello seokgi
Can you say please the reason of having the disabled:
seokgi
Post by seokgi »
It was not working well and I set it to disable.
viktor_au
Post by viktor_au »
Can you try this:
seokgi
Post by seokgi »
Yes. I tried it. But not work
viktor_au
Post by viktor_au »
What is the code results when RX_485 = 0 or RX-485 = 255?
seokgi
Post by seokgi »
result is 0000100001 repeat
thank you
seokgi
Post by seokgi »
Solved.
Max12387 problem.
Thank you every body!
