Compile to chip
JLeith
Has thanked: 146 times
Been thanked: 26 times
Compile to chip
Post by JLeith »
Hi All
Can someone explain why mu program takes 10 min to Compile to the Chip
I have the "Compiler Message"
From the Set Go it took 9min 39 sec to compile to chip
I have attached the Text file with time listed
I have Attached my program
John
April23 File Measge.txt
(8.86 KiB) Downloaded 312 times
Pitcher Master April 24.fcfx
(328.02 KiB) Downloaded 310 times
Re: Compile to chip
Hi John,
Slow compile times are one of the reasons we moved away from the BoostC compiler used for 8-bit PIC devices in Flowcode 6. If you have an antivirus running which is actively checking the running compiler executable then this can make the problem a lot worse.
JLeith
Re: Compile to chip
Post by JLeith »
Hi Benj
Thank you for the information.
? Has Flowcode 6 BoostC compiler been upgraded. I do notice my Team FC complies in seconds. I know it is a smaller design over my Master Flowcode.
John
sundgau
Has thanked: 5 times
Been thanked: 10 times
Re: Compile to chip
Post by sundgau »
Hello Benj,
I just reformat 20 pc. I now very slow in the complication (3mn compilation instead of 30s on my other pc in w7 and w10).
I have the same antivirus on all posts and I can not explain why these 20 posts are very very slow.
I never had this problem before ...Where can the problem come from?
Bruno
(41.18 KiB) Downloaded 1683 times
Re: Compile to chip
Hi Bruno,
Flowcode v6 is a lot slower to compile compared to v7 and v8. Could this be the cause?
sundgau
Re: Compile to chip
Post by sundgau »
Small feedback:
In high school, it's my antivirus (Trenmicro) that blocks the compiler bootc_18f.exe on windows10 but not posts on win7 !!!
At home, it's windows defender that blocks the compiler. Two registry keys need to be changed to disable live virus and spayware scanning.
Bruno
(15.36 KiB) Downloaded 1575 times
