ILI9341 SPI It's not working
Osta
Been thanked: 13 times
Post by Osta »
Sorry!!!
Made a mistake with the settings !
It's working!!!!
JPG
JPG
ILI9341_SPI.fcfx
Proj
(9.23 KiB) Downloaded 239 times
Osta
Re: ILI9341 SPI It's not working
Post by Osta »
By default, the display clears to 320x240.
A default graphics 240x320.
It's confusing.
Hi Osta,
Glad it's working now :D
Change the screen dimension properties so that the entire display is cleared correctly on initialise, the width and height might need to be swapped. Then use the SetOrientation component macro to rotate the display to be the orientation you need.
Use the Position tab of the properties window to rotate the component on the Z axis to allow the sim to match the hardware.
Hope this helps.
